Cadence with second display
exp
Full Member level 1
Full Member level 1
I use Cadence (with X forwarding) with 2 displays.
Cadence always opens new windows on the opposite window.
This is so TERRIBLY annoying!
Can this be turned off somewhere?
Thank you!
Same config here.
Cadence opens window on the main screen. Swapping primary and secondary display (on your client) should solve your problem.
