i want to know the differences between these two product lines? both have its own simulator and schematic capture. but virtuoso have ic layout features. others?
Virtuoso is Cadence origin with Spectre as a simulation tool runnig in *nix platform only, while Orcad is based on Pspice engine working on Windows machine. Cadence just acquired it to make market on all computer platforms. They just put some decorations into it to make it look more like cadence product, but nothing changed much inside. For typical work, Orcad can do as best as other SPICE-like program, which lack of high frequency feature and integrated IC layout tool.
They are actually completely different tools, one of them is aimed at PCB design and layout (OrCAD), it has a PSPICE based spice simulator that is geared to board simulations. Cadence Virtuoso is an IC layout tool only. It does not contain a simulator (that's Specter or Analog Artist). Comparing the above two tools is like comparing apples and oranges.
Added after 2 minutes:
You are not correct, eternal_nan. Virtouso does not just mean for only layout editor. It is named for platform to do full custom IC design and is divided into e.g. Virtuoso Analog Design Environment, Virtuoso Layout Editor, Virtuoso Schematic Editor, Virtuoso Spectre Circuit Simulator etc.
Moreover, OrCAD is not limited to only PCB design. You may used OrCAD together with L-Edit as effective tool for IC design too.
Absolutely, I think so. But their costs are far different and this is the point. Not much companies/universities and no individual person can purchase Virtuoso, while OrCAD is a lot cheaper.
L-EDIT is trademark of Tanner tool, you have to buy it separately.
i am giving in the order of company and then tools
Tanner IC tools (available on windows and linux)
SEDIT-schematic editor
LEDIT-Layout ediror
TSPICE-spice simulatotor for schematics and post layout stuff)
Cadence PCB Tools
in windows
Capture CIS-schematic editor can simulate Bsim mos models so if u want to check some concepts u can do it but no layout for ics
Layout plus&and allegro are its PCB tools
in linux
Virtuoso -Schematic and iclayout
spectre -spice simulator (one of the best simulator the planet has)
Hello,
You are wrong eternal_nan.Virtouso does not just mean for only layout editor. It is named for platform to do full custom IC design and is divided into e.g. Virtuoso Analog Design Environment, Virtuoso Layout Editor, Virtuoso Schematic Editor, Virtuoso Spectre Circuit Simulator etc. .
Ali.
