goatmxj666
Member level 3
Hello. I am doing layout with cadence virtuoso.
When doing the layout, I need a feature where the net selected in the schematic is reflected and highlighted on the layout.
When I pull out a single mosfet, it shows up fine, but when I pull it out symbolized, the highlighted net doesn't show up.
So I'm manually drawing the metal and pressing Q to set the net name in connectivity tab. I would like to make this process a shortcut.
I want to be able to select a metal in the layout, press the shortcut, select the net I want in the schematic, and it will automatically set to that net name. Any advice on how to do this?
Thanks for reading.
Thanks for reading.
