McCauley481
Newbie
Hello all,
Question regarding cadence. So I recieved files that were generated on IC5033, and I have IC6.1.6 so I'm trying to convert them with the translator tool. But I'm not understanding the error messages it's giving me. I placed the schematic in a library of it's own and outside of the folder where cds.lib file is. When I go to select that library it doesn't let me, saying "The cds.lib file specified does not exist or the file is not readable". OK. So I put it in the folder where the cds.lib file is and it tells me:
ERROR (CDBOA-107): You cannot run the translator in the same directory as the
CDBA cds.lib file. Doing so would add OpenAccess library
definitions to the CDBA cds.lib file, which is not
permitted. Run the translator from a different directory.
Just an FYI, the contents of my schematic folder have the following extensions: .tag, .db , .xx , .cd% , cdb
So I just don't understand how I'm supposed to do this. I realize this is retard tier stuff, so any help would be much appreciated.
