pcaocn
Newbie level 6
Hi, guys, I have IC614 and MMSIM72 on my laptop, and I also use NCSU 1.6 CDK.
Recently, I found that I cannot launch virtuoso without Internet, CIW window will wait for Internet for like 5 min and then give up and crash. Here is the log file. Please help me to fix it. Thanks.
\# Program start time UTC 2010.11.09 17:14:13.115
\# Local time Tuesday 9 November 2010, 12:14 pm
\o Program: @(#)$CDS: virtuoso version 6.1.4 11/17/2009 21:10 (sjfnl007) $
\o Hierarchy: /home/pcaocn/Cadence/IC614/tools.lnx86/dfII/
\o Sub version: sub-version IC6.1.4.485 (32-bit addresses)
\# Host name (type): PCAOCN (i686)
\# Operating system: Linux 2.6.35-22-generic #35-Ubuntu SMP Sat Oct 16 20:36:48 UTC 2010
\# X display name (WxH): :0.0 (1400x1050)
\# Available geometry: TL(0:24) BR(1399:1025)
\# X server: The X.Org Foundation
\# Depth of Visual (Root): 24 (24)
\# Number of Planes Used: 24
\# X version: 11.0 (vendor release 10900000)
\# X resource pool: base 0x3800000, mask 0x1fffff (2097151), shift 0
\# current id 0x0, current max 0x1ffffa (2097146)
\# Memory report: maximum data size 4294967295 (0xffffffff) bytes
\# Memory report: maximum process size 4294967295 (0xffffffff) bytes
\# Initial sbrk value: 312627200 (0x12a25000) bytes
\# Maximum memory size: 4026724351 (0xf002efff) bytes
\# Initial memory used: 44384256 (0x2a54000) bytes
\# Qt version: 4.4.1
\# Window Manager: gnome (metacity)
\# User Name: pcaocn
\o Working Directory: PCAOCN:/home/pcaocn/Cadence/works
\# Process Id: 1738
\o
\o COPYRIGHT © 1992-2009 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
\o © 1992-2009 UNIX SYSTEMS Laboratories INC.,
\o Reproduced with permission.
\o
\o This Cadence Design Systems program and online documentation are
\o proprietary/confidential information and may be disclosed/used only
\o as authorized in a license agreement controlling such use and disclosure.
\o
\o RESTRICTED RIGHTS NOTICE (SHORT FORM)
\o Use/reproduction/disclosure is subject to restriction
\o set forth at FAR 1252.227-19 or its equivalent.
\w *WARNING* Unable to export thumbnail MPS services
\o Loading geView.cxt
\o Loading menuBuilder.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading LVS.cxt
\o Loading layerProc.cxt
\o Loading xlUI.cxt
\o Loading auCore.cxt
\o Loading vhdl.cxt
\o Loading seismic.cxt
\o Loading ci.cxt
\o Loading ams.cxt
\o Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.03s.
\o END OF SITE CUSTOMIZATION
\o Loading ./.cdsinit init file from the site init file.
\o Loading NCSU CDK 1.5.1 customizations...
\o loading vars from /home/pcaocn/Cadence/IC614/ncsu_cdk/cdssetup/cdsenv for tool adle
\o loading vars from /home/pcaocn/Cadence/IC614/ncsu_cdk/cdssetup/cdsenv for tool asimenv
\w *WARNING* envSetVal: Can't set the value of variable 'width',
\w in tool[.partition] 'asimenv.plotting' - it has not been registered.
\w *WARNING* envSetVal: Can't set the value of variable 'height',
\o loading vars from /home/pcaocn/Cadence/IC614/ncsu_cdk/cdssetup/cdsenv for tool ddserv
\o loading vars from /home/pcaocn/Cadence/IC614/ncsu_cdk/cdssetup/cdsenv for tool layout
\o loading vars from /home/pcaocn/Cadence/IC614/ncsu_cdk/cdssetup/cdsenv for tool schematic
\o loading vars from /home/pcaocn/Cadence/IC614/ncsu_cdk/cdssetup/cdsenv for tool ui
\o loading vars from ~/.cdsenv for tool asimenv
\o Loading NCSU SKILL routines...
\o Waiting for ipc:0 to initialize
\w *WARNING* Unable to start up library manager (libManager.exe) after 60 tries.
\w There maybe an access or network problem.
\w Start the library manager from an Unix Shell window to test the accessibility.
\w Variable ddsvMPSTimeOut (60) can be set to increase or decrease the number of attempts.
\o cdsServIpc: ipcIsAliveProcess connection timeout (hostCAOCN)Done loading NCSU_CDK customizations.
\p >
\o Loading rte.cxt
\a hiResizeWindow(window(1) list(339:50 1064:243))
\r t
---------- Post added at 03:00 ---------- Previous post was at 02:59 ----------
I think it stuck at *WARNING* Unable to export thumbnail MPS services.
\# Process Id: 1738
\o
\o
\o
\o Loading LVS.cxt
\o Loading xlUI.cxt
\o Loading vhdl.cxt
\o Loading ci.cxt
\o Loading ams.cxt
\p >
\o Loading rte.cxt
\r t
