Cadence Spectre - resistor dependent on equation
harry456
Member level 1
Member level 1
Is it possible to have a resistor in Cadence's Spectre (Spice) that is dependent on an equation like r = 2 * 1/(Vx - Vconst) with Vx as a net voltage?
It is possible in ADE XL environment with 2 tests - 1st for calculating voltage at interest node, which is refered to second one.
Could you be a bit more specific, thanks?
I think this is best done in veriloga (which Spectre digests
just fine, and Cadence supports editing and view-switching).
You will want to error-trap that denominator, and a poly-
source / analogLib primitives kludge probably doesn't have
much for that.
I'd recommend to find a resistor veriloga model, off the Web,
and just mess with the guts.
