caddy
Newbie
Hi there!
I am trying to use a Cadence function 'poParamCellNameMap' to custom my stream-out GDS file. I have checked the function's documentation, and it looks straight forward enough however I cannot get the function's arguments to work, specifically the 'id' arg which is documented as being the sub-master cell's cvid.
For example:
The id~>libName is obviously returning a nil value and therefore causing the (sprintf) function to fail.
If I do the following
My GDS file successfully streamed out and I can see the pcell variants have been named using the (sprintf) formatting above.
The opParamCellNameMap function is naming my pcell variant subcircuits to be 'name_id', but looking at the output above the 'id' arg is being automatically converted to a string value and the ':' of the cvid identifier is being changed to a underline '_'.
My expectation is that the 'id' arg can be used with my procedure to fetch db related objects such as libName, cellName etc, which I can then go on create a custom pcell variant name in the streamed out GDS.
Any ideas? Maybe Cadence has changes the function and I am not aware of the change....
Thanks in advance!
For example:
(procedure (poParamCellNameMap name id)
(sprintf nil "%s_%s" name id~>libName)
(sprintf nil "%s_%s" name id)
Thanks in advance!
