lc2710
Newbie level 1
I am trying to use SKILL code to create a heirachical tree containing all the nets and instances in a testbench. The testbench has many layers and the tree should be able to display the names of all instances and nets inside each instance, exactly like the tree inside the Virtuoso schematic editor. I am having difficulty finding the neccessary Cadence functions - mainly selecting all instances inside a cell view/instance - to do this.
Another problem is that I want my program to be run from the UNIX command line, ideally without opening the Cadence view, which means I will have to specify the library and cell view to access and create the tree from the command line. Is this possible?
All help is much appreciated
