cadence simulation problem
foreveryanyee
Newbie level 3
Newbie level 3
shanghai
what's the acceptable difference between caculation and simulation.
the calculated drain current is much more than the simulated one
the schematic is a simple one, a common source circuit.
the parameter is obtained from .scs file.
thanks
check ur hand calculation
mobility is cgs system all other in um
muz in bsim is cm2/VS
tox can be in imcro...
i advice u to do idvg and id vd sweep and back calculate beta
