fooliojp
Newbie
We recently discovered two transistors connected together via their gate terminals. The connecting net only connects from gate to gate and nowhere else in the schematic. Unfortunately the gate pins for these two transistor devices are defined as direction 'input output'. Therefore the Cadence schematic check does not flag them as floating. If the pins were defined as input pins then this floating connection would have been flagged as there is no input to either gates.
Is there a way I can detect this circuit condition using Cadence's provided checks or a custom SKILL check?
Thanks in advance
Thanks in advance
