Cadence Schematic- how can I get rid of details?
Sadegh.j
Advanced Member level 3
Cadence Schematic
Hi all
When drawing a transistor in cadence, one usually gets a good amount of details on the schematic, how can I get rid of it? When there are many transistors close to each other, this can get very very confusing.
Thanks
Cadence Schematic
in instance properties, there should be drop down menus beside each property for 'off/value/name/both' or something along those lines. some of them are defaulted to 'both', most are defaulted to off.
Re: Cadence Schematic
even i have tried a lot....it doesnt....the default for display is OFF anywaysbut it still shows the details:!:
yeah, It is off, but it shows it. !!!
you can do that by going to Edit ,then component display and checking/uncheking some boxes according to requirement.
