Cadence question concerning virtuoso design environment
saruman1983
Member level 2
Member level 2
Greece
Another cadence question
Hi all,
How can I simulate the transconductance of a transistor and generally a circuit vs. frequency in the cadence virtuoso design environment?
Re: Another cadence question
Hi
I am not sure if this is what you are after. If I am not mistaken, transconductance of a MOS transistor can be simulated in Cadence by doing a simple Ids/Vgs simulation. Then you open up the calculator and use the "deriv" function on the I/V curve. The output should be a transconductance curve for the transistor.
I do simulation with above method, too.
OK, but what if i want to plot the (overall) transconductance of a MOS transistor (not gm, but Gm) for a common source connection for example? The above method requires a DC sweep, then taking the derivative of the curve to find transconductance. I was wondering if that can be done only with an AC analysis,that is when frequency varies and the parasitics of the transistor force the overall Gm to start decreasing.
plot square root of id VS Vgs(or vgs-vt) and find the slope...
then use the drain current equation.
