cadence psd 15.1 linux version installation
binu G
Advanced Member level 2
Bangalore
cadence failed to update cds_lic_file
any know how i can start graphical mode installation .
iam able to start in console mode.
it asked to set the envirment varible but i was not know in how i can set in linux.
binu george
abrir psd no linux
read the inst@llation manual carefully.
cadence psd 15.1
i hve gone through that but it was said to set the env
varrible.
i dont know how to set that in linux
cadence license 15.1
There are different ways todo so depending on your shell...
Suggest you use bash and add it to your ".bashrc" file like:
# Cadence PSD environment
CDS_INST_DIR=/home/user/psd
CDS_LIC_FILE=$CDS_INST_DIR/share/cadence.license
CDS_DIR=$CDS_INST_DIR
CONCEPT_INST_DIR=$CDS_DIR
CDS_SITE=$CDS_DIR/share/local/
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$CONCEPT_INST_DIR/tools/lib
CDSDOC_PROJECT=/CDS_INST_DIR/doc
PATH=$PATH:$CONCEPT_INST_DIR/tools/bin
PATH=$PATH:$CONCEPT_INST_DIR/tools/pcb/bin
PATH=$PATH:$CONCEPT_INST_DIR/tools/fet/bin
export CONCEPT_INST_DIR
export CDSDOC_PROJECT
export CDS_SITE
export CDS_LIC_FILE
export CDS_INST_DIR
export LD_LIBRARY_PATH
export PATH
You can verify your environment with "printenv"
psd in linux
mr. davorin
will this will help to start the installation in the graphical mode
binu
*.psd linux
Nope...
Do you try to install as root or as normal user?
If root...did you enable root access to local x11 server with "xhost +" as normal user before su-ing to root?
environment variable concept_inst_dir
i login in root but the xwindow failed to sart
saying the env is not set.
binug
psd on linux
You didn´t tell us what env variables it asks for...
And login as root is bad idea anyway (o;
Login as normal user and "su" to superuser for installation...
And read my last post about xhost!!!
and...why do you want to use graphical mode installation?
Just go with shell install and your fine (o;
cademce linux version
ok mr. davorin i will try the same
and came back if i found any prob
I am getting the error message 'Failed to start core service:Failed to launch registery server'
Any one has the solution for this.
giara
I can start allegro, but when I type : concepthdl,
it return error!, .....error while loading shared library
libdb.so.3..... abort...
who to correct it? thanks!
fabkiller
You can find libdb.so.3 in rpmfind.net
