Cadence problem with opening cells for editing
husseinadel
Full Member level 3
Full Member level 3
EGYPT,CAIRO
i am using cadence ,,sometimes i built my own libraries and cell views,,then after closing and re-opening ,,a window appears telling me that it fails to open the cell view for editing and asks if i want to open it for read only,,,,,so how can i overcome this problem??? ,,i tried to change the permissions of the files of the cell view to be and library ,,but this didnt work please help
thanks
hussein
ASU
cadence cdslck
search for *.cdslck file in ur view, delete them.
better commands:
1. navigate to ur working directory: cd <my_working_dir>
2. search for these files: find ./ -name "*.cdslck"
3. delete all the resulting files: rm <file1> <file2> <file3>
This will help you, isA.
cadence .cdslck
You may use only one command line to delete all the .cdslck files:
find the_library_path -name '*.cdslck' -exec rm {} \;
Use the following command if you want to view what are deleted:
find the_library_path -name '*.cdslck' -print -exec rm {} \;
