Cadence Library setup for NXP Advanced diode.
whitewiz
Member level 3
Member level 3
LA
how to setup a cadence library
I tried to follow the manual provided from Philips. I put the advanced diode model libraries but it doesn't work in Cadence Library Manager and Path Editer . Please tell me how to setup the model library in Cadence.
This is the link for Philips semiconductor advanced diode library.
I don't know this library, but did you put the path to the library in your "cds.lib" file?
I already put this library in cds.lib like "INCLUDE _Directory/file.so but it has a fatal error running spectre simulation
I found on the website you posted
Spectre
Cadence is using several CMI config versions for different Spectre versions. Once the SiMKit is installed, the correct CMI version is set via the %M option in the CMI config file.
