shanmei
Advanced Member level 1
When I want to add instance/device, I open the "add instance" by click on "i", and click on "browse" from the panel, it turns on the "Component browser" as shown on the right figure. Only one library is shown in the Library column, and I have to select the library I wanted through the Library column in the blue cycle.
I remember that once I click on "browse", it should show the "Library browser" as bellow, which presents all the libraries in the library column in the blue cycle. Then I can see all the library and it is easy for me to choose the desired library.
How can I directly use" Library browser", but not " Component browser" ? Thanks.
