goatmxj666
Member level 3
Hello
Q1.
I'm doing layout the charge pump, but I don't know how thick the metal should be.
I read that 1um/1mA is good, but is the same applied to MOSFETs using fingers? The total width of one of my pmos is 300um. (length=minimum, finger width=5u, fingers=10) * 6
The peak current flowing through the MOSFET and capacitor of the charge pump is 10mA (with no load). When connected to a load, ~50mA flows. Then, should the width of the metal be 40um? (with load)
I think it can be made thinner because fingers are used.
Q2.
What is the good metal thickness of a long wire? (VSS, VDD) ex. over 500um
Q1.
Q2.
