Old Nick
Advanced Member level 1
I'm trying to install cadence on RedHat 6 but things aren't going smoothly. I'm following the instructions Europractice gave us to the letter, using InstallScape, and things sewem OK for the first few packages I install (Assura, Conformal, CTOS) and then configure with the tool, but when I get to EDI and beyond they seem to install but when I run the configuration tool it reports that it has failed.
Also the installscape tool reports the release and EOS date of ever package (including the few that installed/configured correctly) as Nov 30, 1971, which is obviously wrong. Whether that is a symptom or of no consequence I'm not sure.
Any help appreciated, cheers.
I've located the iScape log file for the configuration and the errors it reports are all pointing to a oaRedist22.43-p003lnx86 screenshot attached (hopefully)
