Cadence IC610 errors at startup
sutapanaki
US
I have installed IC610 on Centos 5.3 - 32bit version. When I start icfb, I get a bunch of errors like below. Any idea what is going wrong and how to fix it?
Qt Warning: X Error: BadMatch (invalid parameter attributes) 8
Extension: 153 (RENDER)
Minor opcode: 4 (RenderCreatePicture)
Resource id: 0x44
Major opcode: 1 (X_CreateWindow)
Resource id: 0x44
Qt Warning: X Error: BadDrawable (invalid Pixmap or Window parameter) 9
Resource id: 0x3000011
Qt Warning: X Error: BadWindow (invalid Window parameter) 3
Major opcode: 2 (X_ChangeWindowAttributes)
Major opcode: 18 (X_ChangeProperty)
And this list continues.
The correct solution for this is,
goto you 'xorg.conf' file which can find in path /X11/xorg.conf add below lines;
Section "Extensions"
Option "Composite" "Disable"
EndSection
It should be work fine after that.
regards,
Kumar
    sutapanaki
