Cadence IC5033 Warning Message
T Zul
Member level 2
Member level 2
I sort of have this problem when installing the NCSU Design Kit to the server. Somehow, I got this message at the client:
sh: /mnt/net/IC5033/local/bin/xmesg: /usr/local/bin/wish: bad interpreter: No such file or directory
Can someone shed some light on this issue?
T Zul
check the paths of sh, xmesg, wish, etc. if they do exist.
The path is correct but the xmesg program inside is programmed for Solaris not Linux.
Does anybody modify this program before?
T Zul
T Zul
You may try to trace xmesg if it is a script file.
Do you have tcl/tk installed?
Checked if both apps/scripts are in your PATH with "which" ?
I don't really understand by installed tcl/tk?
Yes, it is a script.
T Zul
tcl/tk is a programming language...if you´re familiar with UNIX you know it (o;
Dunno if it required by C@dence though...
T Zul
You may try to look thru the script and search for something like /usr/bin/sh....
If you found something in doubt, use which command to check if it is available, for example
which sh
Here is the solution from NCSU cadence site.
When we open icfb it keeps saying "sh: /cds/local/bin/xmesg: not found.
We us xmesg to display any site-wide messages at startup time. It's actually a wish script, so I suspect you just need to edit the first
line of xmesg to point to the correct wish executable.
If you want to just get rid of it, you can go into local/cdssetup/cdsinit and comment out lines 164-169 or thereabouts.
