Cadence IC5 display problem on RedHat 7.2
xworld2008
Full Member level 4
Full Member level 4
ic50 display problem?
While using the c@dence IC5 on redhat7.2, I set display as 24bit. everything is OK.But when I open one window,such as waveform plot, schematic, or layout view,I find this view is partly not in the range of display.i can't see the full display,then i can't operate view.
what's wrong with this?
Re: ic50 display problem?
what is the ic50 version? install the latest version.
This is weird. I'v never encountered such problem. Maybe you should reinstalled the software.
I met the same problem.
Set the display as 8 bit mode
it is the linux OS 's problem.use another KDE .
what os do you use, maybe you should use rhel3.0.
Added after 6 minutes:
Linux need dirve of display card, It's better for you to install drive software, and try it letter.
cds just support 8 & 24 bit mode.
