Cadence IC5.1 installation error (Fedora Core 4)
safwatonline
EGYPT
hello,
i have the followin error during installing IC5.1 on fedora core 4
Specify path of install directory \c
[OR type [RETURN] to exit]: \c
/usr/local/cdstree
Setting up softload for lnx86 in /usr/local/cdstree
\c
The following tar errors were detected:
\c
/bin/tar: -b1: Not found in archive
/bin/tar: Error exit delayed from previous errors
Could not set up SoftLoad in /usr/local/cdstree\c
You must have write permissions to install directory \c
and all its subdirectories
and atleast 10 MB available disk \c
space in install directory.
\c
so what shall i do?
libxp.so.6 cadence
If you want to install in /c, follow any one of the below.
1. install in /c from superuser login
2. change the permissions of the /c directory
or
install in a new directory in your login eg: /home/abc/IC5.1 (abc is the login name)
    safwatonline
cadence libxp.so.6
sorry but i am really ignorant about linux , so what is /c , superuserlogin
i am trying to install from root , the tools are at /TOOLS ,
thnx alot
lp: unable to print file: client-error-not-found
This is due to "tar" program too new. Downgrade it to version 1.14 will solve the problem.
    safwatonline
cadence setup plotter
How to downdrade tar program?
cadence plotter printer setup
Try removing it using rpm and installing the tar rpm from FC2.
libxp.so.6: cadence
After downgrade my tar program,
rpm -ivh tar-1.13.25-12.i386.rpm --force
I complete ic5141 installation.
But when I keyin icfb &, a error message displayed:
error while loading shared libraries:libXp.so.6:cannot open shared object file:no such file or directory
Added after 3 hours 13 minutes:
ic5141 works after I add XWindow packages.
cadence install size
hello,
i am not sure but try installing this package from FC3 CD#2
"xorg-x11-deprecated….. .rpm"
regards
install plotter in cadence
Installing as root may create some problems. Instead, install first softload cadence hierarchy and then run softload from this hierarchy ( e.g. <Cadence_Root/install/bin.lnx86) as user not superuser. Otherwise some permission problems occur..
For instance create a directory under root dir and give all permission of this directory to private user and group.
libxp.so.6 cadence shared library
If it's a shared library problem it doesn't matter what user you run it as. It's a system problem.
tar-1.13.25 fedora
I would like to configure plotter for Cadence IC5141 to print schematic giagram remotely. How to get the installation guide for Linux OS?
I got a problem with "client-error-not-found" at this moment.
cadence install site:edaboard.com
just checking is the first error gone, and what u did?
cadence installation guide
Attached is the message from /var/spool/mail/edatool
(the user 'edatool' launched Cadence IC5141)
From edatool@cad3-linux.yyy.com Sat Feb 11 16:06:39 2006
Return-Path: <edatool@cad3-linux.yyy.com>
Received: from cad3-linux.yyy.com (localhost.localdomain [127.0.0.1])
by cad3-linux.yyy.com (8.13.4/8.13.4) with ESMTP id k1B86dlG004358
for <edatool@cad3-linux.yyy.com>; Sat, 11 Feb 2006 16:06:39 +0800
Received: (from edatool@localhost)
by cad3-linux.yyy.com (8.13.4/8.13.4/Submit) id k1B86d6X004354
for edatool; Sat, 11 Feb 2006 16:06:39 +0800
Date: Sat, 11 Feb 2006 16:06:39 +0800
Message-Id: <200602110806.k1B86d6X004354@cad3-linux.yyy.com>
To: edatool@cad3-linux.yyy.com
Subject: Plot Submission Output.
Plot Job Settings:
Plotter: HP2200
Plotter Paper Size: A
Paper Orientation: Automatic
Plot Size: 10.500000 x 7.374046 inches
Plot Offset: 0.000000 x 0.000000 inches
Number of Copies: 1
Header Off
Plot Temporary Directory: /var/tmp
Mail On
Mail Sent To: edatool
Plot Queued Using: /bin/cat /var/tmp/psa04187 | lp -dlp1_txt;/bin/rm -f /var/tmp/psa04187
Command Output:
cadence tmp directory
I can plot my schematic diagram in library manager window directly.
Attached are my installation steps.
0. Share printer service(WINDOW2K) thru samba server
queue name: HP2200 (for example)
1. Verify the printer daemon.
keyin "/usr/bin/lpstat -r"
message shown: scheduler is running
2. Have .cdsplotinit file in home directory.
HP2200|HP2200: \
:manufacturer=Adobe: \
:type=postscript1: \
:spool=lp -dHP2200: \
:query=lpstat -oHP2200: \
:remove=cancel $1 HP2200:\
:resolution#300: \
:maximumPages#30: \
:paperSize="A" 2400 3150 75 75:
