BigBoss
Advanced Member level 7
Cadence that is installed RedHat 7.3 doesn't recognize active component models even I have tried to transform SpectreS models to Spectre format by aid of Model Translation utiliy.
What should I do to use active device models in Cadence ? Everything seems to be ok but when I do a simulation with active devices such as transistors , diodes etc. simulator stops with a error message indicating
that it couldn't find model files or model definitions.
In fact translation from SpectreS models into Spectre does not success.I think the main problem is that.
So neither transient , s-parameter or any simulation that has active devices doesn't work..
Second problem , in Analysis Menu, "Delete" " Disable" and " Modify" submenus are grayed and don't have functionality. So I can not modify or disable or delete any simulation setup.
"Double click" doesn't have any function.
I use Cadence IC 5.032..
Any Help?? ( I'm very newbie to Linux OS )
