cadence ic5.0 display error
xworld2008
Full Member level 4
Full Member level 4
While using the c@dence IC5 on redhat7.2, I set display as 24bit. everything is OK.But when I open one window,such as waveform plot, schematic, or layout view,I find this view is partly not in the range of display.i can't see the full display,then i can't operate view.
what's wrong with this?
I don't know the answer to your question, but let me ask you something else. When you open a wave in the waveform viewer and you put the cursor on it (either A or B), do you have problems moving the cursor along the wave? I encountered this in my installation but I used RH8.0. And there was noo such problem for wavescan.
I used radhat8.0 too and everythings are ok. I know that ic5.0 is certified for radhat7.2, but who knows:)
Do you know if I can use one video card for Windows and a different one for Linux - both in the same computer?
