asueee0
I remotely acess cadence IC5141, and tried the following two programs respectively:
exceed 10: this is the best to use, but unfortunately, the transfer speed is very slow
VNC (www.realvnc.com ): this is not as convenient as exceed, however, the transfer speed is fast enough .
there are some setup in exceed, but i still could not boost the speed after configuration, I believe there should be some way to boost the speed so that it can be as fast as using vcn, looking for help, by the way, i have dsl which is 1.5mbps (actual speed is 1.35mbps)
