Cadence corrupted database
Sarin30
Newbie
Hello everyone,
Following a network outage in my university which occurred when I was editing the layout view of my cell, the view is now corrupted. When I want to open it, Virtuoso shows the following error message:
*WARNING* (DB-270000): dbOpenCellViewByType: Corrupted database encountered: Unable to read feature data from design IC1/Full_chip_TEST_1_GND/layout. Invalid number of flag arrays encountered. Try oaScan to scan/repair the database, revert it to a backed up version, or recreate it.
*WARNING* (DEBASE-102084): Data trigger for viewType maskLayout failed.
After running an oaScan in my library, I get the following output:
Running: oaScan -lib IC1 -repair -fixWarnings
Started: Sun Mar 21 22:27:16 2021
Cellview IC1/Full_chip_TEST_1_GND/layout 'maskLayout':
- data model 2 saved by an app compiled against 22.60.027 running 22.60.028
ERROR: (OA-131): Corrupted database encountered: Unable to read feature data from design IC1/Full_chip_TEST_1_GND/layout. Detected an inconsistent TOC numUsed value for data 'feature': 0.
NOTE: 1 error encountered that prevents the repair of this database.
Cellview IC1/Full_chip_TEST_1_GND_2/layout 'maskLayout':
ERROR: (OA-131): Corrupted database encountered: Unable to read feature data from design IC1/Full_chip_TEST_1_GND_2/layout. Detected an inconsistent TOC numUsed value for data 'feature': 0.
No inconsistencies found in 241 databases
- repaired 0 of 139 designs
- repaired 0 of 102 DMDatas
Finished: oaScan
Time elapsed: 1.93 seconds
CPU Time: 1.06588 seconds
Does anyone know how to fix this?
I put 3 weeks of hard work into that circuit, it would really hurt me if that work was lost... Also, I am using a university license, so I would say that there is no customer support from Cadence.
I am using Virtuoso IC6.1.8-64b-500.9.
Thanks in advance!
1.
Does the university's computer center make backups? Perhaps they have an old version of your database in a backup somewhere?
Or perhaps a disk rescue utility can recover an old version of your database if you provide the operator with a specific name.
They may be reluctant to do you this favor, and you might offer to pay a fee to someone in a position to decide. What's this favor worth to you?
2.
Or else...
Is your database in netlist format or similar?
Can you open the corrupted database yourself? In a text processor?
Can you compare it with any good database, to get an idea what makes the corrupted one different?
There's a chance you can correct the corrupted portion, or else delete it line by line, in hopes it leaves you with a portion that's usable.
Hello BradTheRad,
I tried to open the file with a text editor but the file was too large for the editor to handle it. The computer support group of my department have been able to provide me with a back up file from Friday, so that's excellent, I will only have to redo 2 days of work :)
Thanks for your reply!
