ahmad.mar
Newbie level 6
I am trying to do a mixed signal simulation with AMS under cadence\virtuoso.
this is for an old testbench which was working fine with Spectre simulator,
but then I replace a logic block with a verilog code instead of an old one with veriloga (then I need AMS).
the new Verilog block has no problem, as I am able to simulate it in a separate testbench.
when trying to run the testbench with AMS I got the error message
however in the Netlister Log I do not see any errors or even warnings
and no netlist is generated ....
do you have any suggestions/ comments
generate netlist...
### Generating design information at:/home/aalmaras/Spectre40/sdm_test_logic_run/.tempProjectDir/sdm_test_logic/ams/config/netlist ###
ERROR (45) : Cellview based netlisting has failed.
Check Simulation->Output Log->Netlister Log for errors.
Correct your design and netlist again.
...unsuccessful.
Netlisting ("tests" "sdm_test_logic" "config").
Info: Processing ("tsmcN40" "inv_lvt" "schematic") ...
Info: Found 0 errors and 0 warnings.
Info: Processing ("BlocksTr" "switiID" "schematic") ...
Info: Verilog-AMS netlist successfully written to
~/switiID/schematic/verilog.vams.
Info: Processing ("BlocksTr" "mixed_lgc_tap2" "schematic") ...
~/mixed_lgc_tap2/schematic/verilog.vams.
Info: Processing ("BlocksTr" "NO_clck" "schematicD_ID") ...
~/NO_clck/schematicD_ID/verilog.vams.
Info: Processing ("SD_DAC" "SDM_DAC_lgcTap2" "schematic") ...
~/SDM_DAC_lgcTap2/schematic/verilog.vams.
Info: Processing ("tests" "sdm_test_logic" "schematic") ...
~/sdm_test_logic/schematic/verilog.vams.
Done netlisting ("tests" "sdm_test_logic" "config").
