Cadence 5.1.41 Spectre Error
pasindua
Newbie level 3
Newbie level 3
I am using Cadence 5.1.41 with NCSU CDK 1.5.1, and I am new to Cadence. I have created a simple schematic in Virtuoso. When I try to simulate the schematic using Analog Design Environment (ADE) and Spectre simulator, I got the following error.
*Error* Errors encountered during simulation. The simulator run log has not been generated. Possible cause could be an invalid command line option for the version of the simulator you are running. Choose Setup-Environment and verify that the command line options specified in the userCmdLineOption field are supported for the simualtor. Alternatively, run the simulator standalone using the runSimulation file in the netlist directory to know the exact cause of the error.
Then I found the runSimulation file and ran it, which gave me the following error.
*ERROR* /usr/local/cadence/MMSIM101/tools.lnx86/spectre/bin/32bit/spectre: error while loading shared libraries: libelf. so. 1: cannot open shared object file: No such file or directory
In my case Cadence is installed on a remote host. I am running Cadence through a ssh connection.
Can anyone please help me sort this out? As I said I am new to cadence, and I am lost at the moment. Thanks in advance.
