Cable capacitance issues?
conmanxx
Newbie level 6
Newbie level 6
Hello,
Currently I'm working on a project, we are seeing some strange behaviour.
We are reading inputs through back panel of an instrument. all input lines are pulled high to 5V through 10K resistor.
A simple external contact closure will then pull the input lines low
These inputs are connected to a TXS0108E voltage level translator which converts inputs down to 3.3V,
We observe when we plug cable onto these input lines the outputs of the TXS0108E start flicking high/low intermittently.
We believe the cable capacitance is causing the issue.
Has any one seen similar problems?
Any advice on how to solve the issue?
A buffer maybe is the way to go between the cable and the TXS0108E?
How about debouncing the inputs in software?
Adding hysteresis is it? I.e Input must be constantly low for a period of miilseconds before it is accepted?
Hmm worth considering
Would prefer a hardware solutution!
How about a .1uf capacitor between the input(s) and ground?
As we have no idea what the expected switching rate/frequency is in your application, it is kind of hard to suggest a value, but a simple low pass RC filter on the input should do it - if the wiring is going out to mechanical switches/relays, you should probably have some filtering and/or transorbs or clamping diodes on the inputs anyway to protect from switching transient voltage spikes.
