C to assembly translator?
LatDrIvE
Member level 4
Member level 4
athens
assembly translator
hello all, i would like to ask if there is any c to assembly or assembly to C converter....
Which is the best program to simulate DLX instructions?
regards
lat
c to assembly translator
C -> assembly is usually done with a compiler. Most compilers have options to output assembly source instead of object files.
assembly to c translator
If you use windows then WinDLX is a good simulator for you.
If you work with linux try DLXview.
Here's a link to both:
