zawminoo
This source is servo motor control with PIC18F452. and it is OK..I tested.
Please help me to change code for PIC16F877A.
Please help me change code for PIC16F877A.
Thank
int servo1,servo2,servo3;
void servo_1(int servo1);
void servo_2(int servo2);
void servo_3(int servo3);
void initial(void);
void check(void);
void move1(void);
void move2(void);
void stop(void);
void interrupt(void);
void main()
int i,adc;
ADCON1=0x8e;
trisb=0; // PORTB IS OUTPUT
trisd=0xff; // PORTD IS INPUT
tmr0h=0xfc;
tmr0l=0xee;
intcon=0xa0;
t0con=0x87;
portb=0x00;
portd=0x00;
while(1)
initial:
servo1=500; // HOME POSITION
servo2=500;
servo3=500;
delay_ms(5000);
//------checking sensor--------------
check:
if (Button(&portd,3,0,1)) // SENSOR1 PORT
{goto move1;}
else if (Button(&portd,4,0,1)) // CHECK SENSOR 2
{ if (Button(&portd,5,0,1))
{goto move2;}
else
{ goto check;}
//---------move1-------------
move1:
for(i=0;i<133;i++)
servo1--; // SERVO 1, AND 2 ROTATE 20 DEGREES CLOCKWISE
servo2--;
servo3++; // SERVO 3 ROTATE 20 DEGREESS CLOCKWISE
{ goto stop; } // IF GRIPPER SENSOR HIGH, GO TO STOP
else {}
delay_ms(10);
for(i=0;i<67;i++)
servo1--; // SERVO 1 ROTATE 10 DEGREES CLOCKWISE
servo3++; // SERVO 3 ROTATE 10 DEGREES COUNTERCLOCKWISE
else {}
delay_ms(10);
for(i=0;i<267;i++)
servo1--; // SERVO 1 ROTATE 40 DEGREES CLOCKWISE
else {}
delay_ms(10);
goto stop;
//---------move2------------------------------
move2:
for(i=0;i<133;i++)
servo1++; // SERVO 1 ROTATE 20 DEGREES COUNTERCLOCKWISE
servo2--; // SERVO 2 AND 3 ROTATE 20 DEGREES CLOCKWISE
servo3++;
if (Button(&portd,5,0,1)) // IF GRIPPER SENSOR HIGH, GO TO STOP
{ goto stop; }
else {}
delay_ms(10);
for(i=0;i<67;i++)
servo1++; // SERVO 1 ROTATE 10 DEGREES COUNTERCLOCKWISE
servo3++; // SERVO 3 ROTATE 10 DEGREES CLOCKWISE
else {}
delay_ms(10);
for(i=0;i<267;i++)
servo1++; // SERVO 1 ROTATE 40 DEGREES COUNTERCLOCKWISE
else {}
delay_ms(10);
goto stop;
stop: // STOP ALL SERVO MOTORS
delay_ms(5000);
goto initial;
//-------interrupt-----------
void interrupt() // FUNCTION TO GENERATE PWM
if(intcon.tmr0if)
tmr0h=0xfc;
tmr0l=0xee;
intcon=0x20;
servo_1(servo1);
portb.f4=0;
servo_2(servo2);
portb.f3=0;
servo_3(servo3);
portb.f2=0;
while(servo1>0)
portb.f4=1;
servo1--;
while(servo2>0)
portb.f3=1;
servo2--;
while(servo3>0)
portb.f2=1;
servo3--;
Thank
