C++ Programming. String Check for the valid pair of brackets.
macer_0001
Member level 1
Member level 1
Manila
I am using is C++ programming language.
Could you please help me about the program I am working now?
The program is all about checking the string for valid pair or pairs of bracket/s.
Then printed "Valid" or "Invalid".
Here are the samples:
Input: Output:
{}dsafsdf Valid
jjhfsajd[] Valid
[sjj<df>] Valid
]sdafasd[ Invalid
(sfd<sf)> Invalid
(dsfsdfsd Invalid
sfsdfsdfsf) Invalid
(){}[]<> Valid
({<[]>}) Valid
Thank you in advance.
You may try "Regular Expressions" to check these patterns
Search "Regex in C++", "Regular Expressions in C++"
Try this:
Stack.h
// implementation file for a stack class
#include <iostream>
using namespace std;
const int stack_size = 1000;
class stack
      private:
         // data for the stack
         char data [stack_size];
         // the index of the top element of the stack
         int top;
      public:
         stack ();   // constructor creates an empty stack
         void push (char item);  // puts item on the top of the stack
         char pop ();   // removes and returns the item at the top of stack
         bool empty ();
         bool full ();
// initialize the stack to an empty stack
stack::stack ()
   top = -1;
// push adds a new element to the top of the stack
void stack::push (char item)
     // if the stack is full, error
     if (full ())
        cout << "\n\nStack Error: pushing on a full stack";
        cout << "\nThe item being pushed is " << item;
     else  // OK to add the element
           top++;
           data [top] = item;
// pop removes and returns the top element of the stack
char stack::pop ()
     // if the stack is empty, error
     if (empty ())
        cout << "\n\nStack Error: Popping an empty stack";
        cout << "\nReturing a ?";
        return '?';
     else // OK to pop
          top--;
          return data [top + 1];
// empty returns true if the stack is empty, else it returns false
bool stack::empty ()
     return top == -1;
// full returns true if the stack is full, else it returns false
bool stack::full ()
     return top == stack_size - 1;
Here is the program:
  Program reads an expression terminated by an s, and tells whether the
  parentheses (), [], and {} match correctly or not
#include <cstdlib>
#include <iostream>
#include "stack.h"
int main(int argc, char *argv[])
    stack equation;  // stack of open parentheses
    char ch;         // current character
    char popped;     // an element popped off the stack
    bool good;       // true if everything matches
    good = true;
    cout << "Enter an equation followed by an s:\n";
    cin >> ch;
    // continue reading an processing characters until an s is read
    while (ch != 's')
          // if it is an open parenthesis, put on the stack
          if (ch == '{' || ch == '[' || ch == '(')
                 equation.push (ch);
          else
          // if it is a close parenthesis, pop the stack and match
          if (ch == '}' || ch == ']' || ch == ')')
                 // stuff on the stack, ok to pop
                 if (! equation.empty ())
                    popped = equation.pop ();
                    // if the characters don't match
                    if (! (popped == '{' && ch == '}' ||
                        popped == '[' && ch == ']' ||
                            popped == '(' && ch == ')'))
                    good = false;
                 else // nothing on the stack
                      good = false;
          cin >> ch;
    if (good && equation.empty ())
       cout << "\n\nYes, it matched";
    else
        cout << "\n\nNo, it was bad!";
    cout << "\n\n";
    system("PAUSE");
    return EXIT_SUCCESS;
