C programming in gLCD - Help
Maverickmax
Advanced Member level 1
c code for glcd avr
Hi
Have anyone done C programming with 8051 and 128*64 Graphic LCD module before?
Maybe with AT89C51 or AT89C52.
Maverickmax77
glcd programming in c
yes. what do you want to know. It is not that difficult.
    V
8052 glcd
Hi techie
Do you have code for controlling gLCD with AT89C51 or AT89C52?
Maverickmax77
    V
tcb1335
see : **broken link removed**
but c for AVR
glcd programming
Hi Maverickmax77,
There are many different graphic LCD modules. Some comes with built-in controller, some doesn't. There're also different kinds of LCD controllers (e.g. T6963, SED1330). You need to check your LCD module.
HTH
glcd and button programming
There are C code appilcation notes avaialable for T6963 on the internet. But normally 128x64 LCDs use KS0108 or similar SED controllers. But you can get some idea from the application notes.
glcd c code
You can see in many lcd interface with 8051 here.
please i have a glcd controller called tcb1335 and it's glcd, but i dont have the library c file that i can use to interface it, so any 2 have it ,or any project that done b4 about that
note the glcd mpdel is lm2028.
thanks..
    V
