c program for matrix muliplication
jakjoud
Full Member level 2
Full Member level 2
Marrakech
Matrix inversion
Here is a source code in C for inversing matrix.
I hope it will help
Re: Matrix inversion
This is already given in EFY CD of month oct.
Matrix inversion
I just get it from one friend. I don't have this CD
In fact it's applying a method called "gradient conjugé" in french! it's a useful when you're trying to work with big matrix
Will this work for complex matrix. If the matrix is rank deficient will this give a psuedo inverse. which inversion method is computationwise most effective. I wanted to implement complex matix inversion in a DSP processor.
Matrix inversion
First this works for complex matrix.
second I didn't undersatnd you second sentence "If the matrix is rank deficient will this give a psuedo inverse".
Third there are a lot of inversion matrix methodes and every one has a domain of applicability I can not say that there someone which more efficient in general than the others. But I think it depends on the matrix kind and size!
For inversing a matrix in order to solve a linear system, a lot of methods exist.
Obviously, the use of a method rather than another depends on dimension and nature of the same matrix.
Which kind of matrix are you considering? I mean, is it a sparse matrix? Is an Hermitian one? what about elements? ..are they complex or not? Is the matrix a square one? what is its dimension?
Thx
Nicola
