C++ program error: unhandled exception in mnas5.exe
fatma1000
Banned
Full Member level 2
eygpt
helpdez
when i run my program in c++ i have no error in compile but for run i have this message
"unhandled exception in mnas5.exe.:0xc00000FD,stack over flow"
please explain it to me
Re: help10 c++
is this messege is shown by compiler visual in black window or it is given by windows
there r many possibilities
1)your .cpp file has such coding that if a required input is not available it will show address and give this messege
2)your compiler instalation would b corrupt
3)u r not using an administrator account on windows
4)ur RAM is full
normally when we studied c++ we used such codes at display if the RAM gets full
help10 c++
stack overflow, as ehsanelahimirza stated, is usually mem leak that causes an error.
Re: help10 c++
Stack overflow can occure if you have very deep recursive function call. This will cause stack to overflow. Run the program under debugger, and see where it fails.
Re: help10 c++
memory leak or memory lack
