C language - pointers to functions
impakt
Member level 4
Member level 4
Hello all,
I have a problem with understanding how pointers to functions work. I have some books at home, but there is poor explanation on this. Is there an article/book/link that explains how pointers to function work, but explained for dummies? Do you know something like this?
Thank you!
impakt said:
Hello all,
Thank you!
Nobody? :cry:
They are not that difficult. A function pointer just contains the address of the entry point of the function.
If you have a function like:
int myfunction(int x);
you declare a function pointer that matches the arguments:
int (*myfunctionpointer)(int x);
The brackets define it as a function pointer.
Then you can assign the entry address of your function to it.
myfunctionpointer = myfunction; /* one way */
myfunctionpointer = &myfunction; /* Another way */
Then you call it like you would call the function:
answer = myfunctionpointer(argument_x);
There are many places were they help in writing elegant afficient code.
A simple example is in a menu system where the selection is an index into an array of functionpointers.
Here is a small example of a switch statement implemented as an index into an array of state function pointers. The return from the called function is the state switch.
/*--- State Machine ---*/
enum STATE{IDLE_S = 0, MASSAGE_S, LUMBAR_S, BOLSTER_S, ERROR_S};
/*--- State machine functions. ---*/
enum STATE idle(void);
enum STATE massage(void);
enum STATE lumbar(void);
enum STATE bolster(void);
enum STATE error_state(void);
/*--- Program entry point ---*/
void main(void)
  enum STATE (*const Pump_State[])(void) = {idle, massage, lumbar, bolster, error_state};
  enum STATE State = IDLE_S;
  for(;;)
    State = Pump_State[State]();  /* execute state machine */
/*--- End of File ---*/
Hello btbass,
For this example do you have also the classic implementation of the switch statement? This would help me get a better view of this implementation.
Thank you!
The same example as a switch statement would be:
void main(void)
  for(;;)
    switch(State)
        case IDLE_S: State = idle();
                     break;
        case MASSAGE_S: State = massage();
                        break;
        case LUMBAR_S: State = lumbar();
                       break;
        case BOLSTER_S: State = bolster();
                        break;
        case ERROR_S: State = error_state();
                      break;
        default: State =  ERROR_S;
This is a trivial example. Once you start using them you will find they can provide a nice clean solution for a lot of programming problems you might come up against.
