C code for sending packets through COM1 (RS232)
FuzzySNR
Member level 2
Member level 2
Anyone could give an example in C code prefferably of how to send these packets through COM1 (RS232), setting up a connection channel between server-client at 9600 baud. A liitle catch here...the server is only allowed to send the next packet after the client has echoed the packet back to server. The latter should listen for the return packets and only issue the next sync. packet after it has received the appropriate echo.
For example,
Sync0: 0xFA, 0xFB, 0x03, 0x00, 0x00, 0x00
Sync1: 0xFA, 0xFB, 0x03, 0x01, 0x00, 0x01
Sync2: 0xFA, 0xFB, 0x03, 0x02, 0x00, 0x02
Cheers!
Re: RS232 Help
Without writing anything special, you can use this terminal software:
http://www.rfinnovations.com.au/Uploads/Images/RFI-Interm Rev1.1(1).zip
Just right-click on tabs (buttons) to set them up; each button can send a string consisting of HEX or ASCII characters ..
There are 20 levels and each level has 10 buttons .. see picture below ..
Regards,
IanP
Re: RS232 Help
I have already ckecked that, thanks, but I actually need some C code to integrate it to my application. Any one who can give me some example?
