C code/ Floating point num
Mina2016
Junior Member level 1
Hello,
In C code below why I cannot use float to declare pointer to the floating point number. It has used “char” but I don’t understand why.
could you explain it to me?
Code C - [expand]
8
9
10
11
#include "stm321476xx.h"
‡include <stdio.h>
unsigned int a = 1;
unsigned int b, c;
float x = 3.0;
int main () {
// declare pointer to the  floating point number x
char *ptr = (char *)&x;
Thanks
My teacher told us that we cannot use float pointer here. I am not sure, but I guess due to having “int main “command, we cannot point to the floating numbers by float pointer.
int main has nothing to do with this.
I suggest you replace the char pointer with float pointer and run the program and see what does not work.
We can help you if you have clear problem statement.
