C book to learn Embedded
vinothmct
Member level 1
Member level 1
I consider my c knowledge to be above average. I can write a logic . I have written driver for several peripherals . I wish to be strong with C language . How much memory variable occupies etc . Do u guys recommend any book for me?
Which microcontroller/platform are you interested in?
If you are interested in working on AVR micro-controller here is the best book for programming.
--> The AVR Microcontroller and Embedded Systems: Using Assembly and C by Muhammad Ali Mazidi, Janice Mazidi, Sarmad Naimi, Sepehr Naimi.
all the best.
I dont want embedded books . I want C books to learn all the basic embedded C
This book contains C code also.
Just check it out.
If it is not of you interest just leave it.
BTW , to write embedded C code you should have basic knowledge of the hardware too.
and check out this thread also.
https://www.edaboard.com/threads/120857/
If you are really looking into Hardcore C coding then don't go for embedded or microcontroller oriented books, go for Operating systems or Networking based C coding books, for example
Go for the below book
operating systems concepts by Galvin
https://books.google.co.in/books/about/Operating_System_Concepts_6ed_Windows_Xp.html?id=s0MUQn7cxA4C
The best way to master a programming language is to go on coding,
write device drivers, linux or windows, in this case you can look at the real time output of your code.
Sorry i forgot to tell this,
the above mentioned book is a very good book which gives extensive knowledge of operating system with c code snippets on every topic mentioned and it definitely helps in mastering operating systems concepts.
Cheers!!!!!
Reactions: zia
    zia
