C# Arraylist with class
islouis
Junior Member level 1
c# arraylist of class
Dear Sir:
Im new to C# and Im trying to assign multipe object into Arraylist and the code as follow:
using System;
using System.Collections;
class contact
public string Name
get
return name;
set
this.name=name; //should this be Name=value;?
string name;
public string Status
get
return status;
set
this.status=status;
string status;
public void Setdate ( string status, string name)
this.status = status;
this.name = name;
class entry
public static void Main()
contact obj = new contact();
ArrayList container= new ArrayList(100);
obj.Name = "John";
obj.Status = "Online";
container.Add(obj); // I want to pass it into ArrayList, but exception
obj.Name = "Peter";
obj.Status = "OFFLINE"; // Now i create another obj and want to store into the ArrayList
container.Add(obj); // so now should have multiple object contain inside the ArrayList?
for (int i=0; i<container.Count; i++)
Console.WriteLine("{0} ", container); // How do i print it out?
There is a lot of mistake in above code, but what i really want to do is trying to assgin multiple "contac" object into Arraylist. So, if there is any advice is wellcome.
thanks!
Louis
counting multiples in a c# arraylist
i have fixed the issues in your bug and left for you to analyze what i have modified, analyze it and try to think why this was done.
using System;
class contact
public string Name
get
return name;
set
name=value;
string name;
get
return status;
set
status=value;
string status;
this.name = name;
class entry
contact obj1 = new contact();
contact obj2 = new contact();
ArrayList container= new ArrayList(101);
obj1.Name = "John";
obj1.Status = "Online";
container.Add(obj1); // I want to pass it into ArrayList, but exception
obj2.Name = "Peter";
obj2.Status = "OFFLINE"; // Now i create another obj and want to store into the ArrayList
container.Add(obj2); // so now should have multiple object contain inside the ArrayList?
Console.WriteLine("Name = {0} Status = {1} ", ((contact)container).Name,((contact)container).Status); // How do i print it out?
    islouis
c# container.add
Thanks a lot!!!!
I think i know what's wrong with my version now! thank!
Louis
