BZX79C10 & BZX79C12 zener Substitute
rajaram04
Advanced Member level 3
earth
Hello sir
I want to know about substitute number for BZX79C10 & BZX79C12 . . please help . .
You have a lot of trouble finding parts that are common in the rest of the world.
The datasheet for the BCX79C series shows that their voltage is rated when they conduct only 5mA.
A 1N6000B is the same as a BZX79C10 and a 1N6002B is the same as a BZX79C12.
You can use BZX55C or BZX83C instead of BZX79C and the voltage numbers are the same.
ya exactly i ve the same problem as you told , but thats also a part of my mission or aim whatever it is
I ve to manage a lot of things sir then only i can proove what i anounced . . ll tell sometime
well okk i ll follow as per datasheet . . :) thanks
