visher
Newbie
I have this tiny little brushless fan in the car's mirror which has a purpose of blowing fresh air onto humidity and temperature sensors.
Unfortunately they are prone to cause annoying vibrating noise, I have tried a few used ones and all of them did the same. New part is unavailable, producer changed the design to not include the fan anymore but it's not backwards compatible.
I thought about removing the fan completely, by bypassing it with a resistor (otherwise a fault is recorded in the AC module and there are no sensor readings if I just unplug the ground wire from the fan) but my electronics knowledge is so basic and limited that I could not cope with it. Did a few measurements though.
There is 12v and GND going into the fan, but then the 12V kinda "continues" through the fan into the sensor board.
During operation at 12.09V, the voltage on this "output" drops to 11.16V. Resistance measured between the two red wires shows 22Ohm. When I stopped the fan using my fingers, the voltage started dropping more (to 10V etc)
Resistance between GND and 12V input is around 477 Ohm, whereas resistance between GND and the 12v "output" is 450 Ohm.
This is the connection schematic from VISU
Could you help me out bypass this annoying fan completely or at least slow down the RPMs to mute it a little? Or is it even possible to achieve?
I guess I could put a resistor between the 12V input wire, but that would also lower the voltage on the "output" which I'm not sure what it even is.
