AndreasC
Newbie level 3
Hi
I'm designing some circuitry to control lights and headlight motor control of a 1/8 scale car model. I have a small DC motor that draws around 300 mA at approx. 9 V but I also want the possibility to drive a bigger motor if needed, e.g if the motor dies and I need to change it, it's always nice to have the possibility to install a bigger one. I don't need the possibility of driving a motor that draws more than approx. 1 A though. I want to connect this motor to a main control board where all the control electronics sit. The motor is controlled in both directions through some circuitry on the main board and the power supply is connected to the same board.
I want to place a bypass/decoupling net across the incoming power supply for the motor to cancel out noise from the motor and I reckon I would need a big electrolytic capacitor for this.
My question is basically, would I need some ceramic caps in parallel with the electrolytic, what specs etc? How could a functional and effective net look like. Some over engeneering is always ok in my view.
