buying a simple oscilloscope
thebadtall
Full Member level 6
Full Member level 6
Hellas
hello, i would like to buy a cheap oscilloscope, i could buy a used from you,
but im watching at ebay some cheap ones, and would need info about what specs to focus on.
for instance this
https://www.ebay.com/itm/2-Channel-...51939?pt=BI_Oscilloscopes&hash=item4d011e68e3
mentions, measurable frequency 3khz, wich i think it cannot measure the full audiable range, and i cannot know if my amplifier is bad at higher frequencies...
sampling rate, analognbandwidth etc.. thank you!
hi, Thebadtall.
"Max sampling: 8kHz x 1/ (4kHz x 2)" This is a funny parameters, usual PC sound card will be better.
Hello thebadtall,
it's a nice toy, but no more. :roll:
With this device you can not measure anything in audio or digital circuits. The frequency range and also the voltage range is to low.
If you want to buy "only" an oscilloscop look for HAMEG or Philips like **broken link removed** or **broken link removed** or **broken link removed**
I know this scopes and they are very good.
Regards
Rainer
try to go for better oscilloscopes if you want to view freq in audio range so kindly look for scopes having larger band width
other wise buy it and remodify the entire ckt that may be cumbersome
Dear Rainer
Thank you for suggestions, but those sellers (and 99.9% of ebay.de) does not ship to Greece ,and I cannot understand why.
However , I have take a taste of what you mean, and realised that I should buy something "real" instead of "cheap"
Thank you !
Dear DeepOne, yes, about "toy" you are right, after a brief search I done.
Dear Jeffrey, thank you for claryfying the Bandwidth matter.
with an arduino you can make an xpeyes i guess. but i want an osciloscope (a serious one)
