Patwong
Newbie
Appreciate some help here to design a circuit
I would like to control a pulse solenoid valve. The pulse solenoid works by positive input voltage pulse, the valve open, reverse the voltage pulse, the valve will close. then no voltage is applied, the valve state remain as it was.
I would like the circuitry to be simple and consume only power when the button is press ( so not microcontroller or arduino here). The preferred power source is a 18650 battery (3.7v). 1 battery or at the most 2 battery to power the circuitry. When the button is release, the whole circuitry is open and therefore no power is consumed.
When I press a button, the positive output voltage will be generated (can be a pulse or so long as the button is press, then output voltage is maintain). when the button is release, there is no voltage applied. When the button is pressed again, a negative output voltage will be generated.
Below is what I am trying to achieve
