skywalker898
Member level 1
- Joined
- Jan 31, 2012
- Messages
- 32
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Madison, WI
- Activity points
- 1,622
Hi this seems like a silly question, but we've spent way too much time searching and don't see a clear answer anywhere. We have a rackmount electronics enclosure we are going to mount some custom PCB's in, and we would like to find a small din rail terminal bus just to power each of the boards. Each board needs a line and neutral from the wall, and we have a din rail mount inside, but we can't figure out what the part is called that is simply a bus that connects to a din rail for say 120V. We want to put the Line and neutral into separate din rail terminals, and connect wires from each din rail terminal to all the PCB's. What is this device called?
Thanks,
Brandon
Thanks,
Brandon
