Bus for connecting ARM + DSP
DarwinAlonzo
I am thinking that for some specified application which ARM-base processor and DSP works together.
What's the type of bus between two processors, which could enhance the total computation power?
Are they 'memory shared' (it seems too complicated for s/w design) / SPI/ GPIO (speed too low)?
:idea: I know TI, philips, atmel....they have DSP/Codec + ARM inside single chip. But any sugguestion for discrete them.
Hi
You can use the philips LPC22xx ARM with external bus to connect the dsp as an external memory device
All the best
Bobi
Maybe you don't need additional DSP with ARM core. New ARM cores have support for DSP operations. So choose some ARM9 or higher architecture.
yes,arm9 include dsp core,you could select one
hi all
can anyone suggest me as to how to implement Voice Over IP or MP3 codec for ARM7.what all specific areas i need to know to accomplish this task?can anyone send me some mirror links ,where i could get source code?pls help me.
regards
john
Hi
I think the newst release of AMBA Bus has a fast AHB link to IO's which could be used to connect to DSP
Salam
Hossam Alzomor
I think the DSP from analog device ,like BF533
Hi
I think you can use the Ti's newst chips which intergated DSP+ARM.
