danny davis
Banned
At work there is PCB boards that are BURNT because of the components got very hot and burnt to black themselves
How do you know is there is carbon in the PCB board now? my manager calls it carbon substrate
When the PCB board is BURNT , and you put new components ontop of the burnt pcb , what happens?
Is the BURNT pcb board a parallel path for current?
Is the BURNT pcb board have resistance? does it add resistance to the traces where it's burnt?
My manger used a Fiber glass eraser to erase the burnt PCB board, but it just makes a PIT in the PCB but it's still burnt
My manager said you can lay components over the BURNT PCB board because the BURNT PCB board doesn't do anything to the circuit, is this true?
The BURNT PCB board does touch other pads and traces
It's a double sided PCB board
If the BURNT PCB board didn't touch other pads or traces would this be true that it won't do anything and you can lay new components ontop of it and solder new ones in place even tho it's burnt underneath?
