Bulk capacitor series with 1 ohm resistor
PA3040
Advanced Member level 3
Hi
I found attached schematics image which has red cycle that has bulk capacitor series with 1 ohm resistor . Can I know the reason series resistor hare as well as the capacitor does not mention the polarities
Please advice
Thanks in advanced
We are using capacitor with series resistors in some cases to increase the ESR intentionally, e.g. with a ceramic capacitor as bypass capacitor for voltage regulators that require the ESR for stability. Also to reduce the Q of LC low pass filters. In this place, the series resistor doesn't seem to make sense.
Maybe to reduce the current surge when something is connected to the right connector (which has the "VMM" net).
Reactions: PA3040
    PA3040
This capacitor+resistor in parallel with another capacitor configuration is used to dampen inductive resonance in power supplies due to the interaction of parasitic inductances with bypass capacitors.
If you want to read more about it, Google the title of this article: “Bypass or decouple your way to power supply noise reduction”. EDN and EEtimes both have the same article I’m referring to.
Reactions: PA3040
    PA3040
I also believe that this may be used protect from surge current because at the beginning of the capacitor consume high current and result is low voltage at the output, then regulator try to increase output violate by reference with feedback
