VisheshG24
Junior Member level 1
I am trying to build a transimpedance amplifier with the following specifications:
According to opamp theory, the transimpedance gain of the above circuit will be -R.
I want to replace the opamp in the above circuit with a transistor voltage amplifier implementation as to take the whole circuit to an ASIC design.
I tried making the opamp using mos differential pair with single output as follows:
The problem that I am facing with this voltage amplifier implementation is that the M1 transistor is going in the linear region when Iin goes from 5uA to 10uA and the M4 transistor is always in linear region, which makes it a bad current source. Which ultimately gives a very variable transimpedance gain.
If someone can help with either improving my voltage amplifier implementation or can suggest other simple voltage amplifier circuits that people use, I will really be grateful. Or even suggest any other method to implement the TIA that can match my specs, I will really appreciate this.
Thanks
- The input current range is 100nA-10uA.
- The bandwidth requirement is 100Hz.
- The output voltage should be from 0V-4V.
- I have the vdd=+5V and vss=-5V.
Thanks
